TorqNM T4 10W-40 high performance engine oil
yung
2,000 RPM
synthetic high performance engine oil
TorqNM T4 10W-40,is a high performance synthetic blend multi-grade engine oil designed to meet the demands of high performance engine in modern vehicle TorqNM T4 10W-40 exceeds the latest industry performance standard required in today's automotive engine
why want to use this oil? feature and benefit
TorqNm T4 10w-40 is formulated with synthetic,highly refined base oils and modern additive package to enhance its' thermal and shear stability to ensure a maximun engine protection against engine wear in the harshest of driving conditions. it's formulation provides superb protection in a wide temperature range and also,FUEL SAVE/REDUCE FUEL CONSUMPTION,REDUCE ENGINE NOISE,ENGINE PRESSURE RAISE WHEN ENGINE IS WORM
application
TorqNm T4 10W-40 is recommended for use in all type vehiche,especially modern petrol or diesel engine equipped with turbo-charger super-charger vvt,vtec,mivec,dvvti engine.
MANUFACTURED BY:ISO9001;2000
RM115 ONLY
call 014-6411291 to order
bumpppp
---------- Post added at 11:39 PM ---------- 6 hour anti-bump limit - Previous post was at 08:11 PM ----------
bump..........
---------- Post added at 11:40 PM ---------- 6 hour anti-bump limit - Previous post was at 11:39 PM ----------
bump..........
---------- Post added at 11:42 PM ---------- 6 hour anti-bump limit - Previous post was at 11:40 PM ----------
bump........
