Tom got TiTANed!!
ninja_iga
3,000 RPM
Tom's Review and Comments
comparisions between stock Bilsteins and TiTANs
TiTAN's sifu, Richard custom builds every set for you!
Quality products by TiTAN.
Tom's comments
"Feel:
Where it all comes down to. Result. A few presses on the 4 corners confrims the car has become so much more stiffer. I drove. I just can't believe the difference. It's so much better than i expected. Bumps, potholes debris, sand, stones, road patches, are all neutralized by the Titan shocks. I can now practically skim over them with minimal disturbance in the cabin. Road feel has increased in a good way and the car will react well and follow the road contours. Steering response has improved while cornering and sharp turns will not mess with the Titan's Shock perfomance.
Braking and acceleration feel has also improved dramatically, the car now never squats on sharp acceleration or dive during hard braking especially braking into corners. Slalom swerves are very well managed.
High speeds on highways is also where the Titan suspension will prove its capabilities. The road feel is fantastic on tar and even on concrete roads. Road feel, road feel, road feel. Great! little up and down slopes is always a nightmare and will often shift a car right left, up and down. Not with Titans. The car is quickly absorbs the change in road contour on upslopes and quickly pulls the car back on the ground when you go down the slopes. Fantastic. Needs some getting used to since there is little travel from the shorter stroke and the car's ability to return back to "shape" so fast.
But i did feel the subtle bounce on the not so flat highways. Again, Titan was happy to remedy this. Richard suggest reducing the damping rate of the rear shocks, back to testing and it fixed it right away. "
Originally posted by bazet@Jul 21 2004, 04:49 PM
may I know the spring rate for front and rear ?
brader, what spring rate u tokking ler..
he's using back his EIbach prokit...
just replaced the stock abs with TITAN Tuned ones.
ohh..too fast to type before check the pics...
sorry :)
Thinking of doing that too, since my rear absorbers gonna die
hahah
because DMS and TiTAN's have few things on common..
inverted monotube
custom build-tuned
emphasis on quality
expensive, haha
but pls do take note that Drummonds (DMS) are about RM7500 !!
:o :o
stan,
for non adjustable.. can be it used with sport spring? can the titan withstand the spring?.. because normally OEM shockers cant last long using those sport spring...
if the we are not statisfied with the ride can the it be tuned again for those non adjustable titan
is the warranty same as those coilover ones? 2 years and free 2 years tuning?
and what is the working lifespan for both titan :D
Originally posted by chew118@Jul 23 2004, 11:06 PM
stan,
bro
it's usually not recommended to use sport springs.
Can TiTAN take them springs? Sure bring 'em on!
but your car sure senget one side one.. hehehe that's why the height adjustables are useful!
and usually 'sport' springs are quite soft!
OEM stuff dun last long BECAUSE the shocks bottom out ALL the time, hence short lifespan..
oh of course, if it's not satisfactory, then pls by all means, bring it back, and we'll work on it. "non-adjustables" means it's NOT HEIGHT adjustables.
damping rates are still tunable.
YES warranty is the same 2 years.
NO, fine-tuning is only valid for the first running in period to achieve the 'satisfactory' settings. NOT the full 2 years..
working lifespan is projected to be 24 months. And assuming you service it every 18 months after that, it's virtually a lifetime shock absorbers.
cheers!
Originally posted by ninja_iga@Jul 22 2004, 08:04 PM
:lol: wakakakaaka
you got time, i spray for you new color :P
you spray I don't want lah, but if your gf introduce me her gf S&A then I want lah :) haahhahahaha
Pls deal with TiTAN's boss = Richard directly
TiTAN will not be appointing "middle man" anymore. For all enquiries and purchases, please call TiTAN's office directly and look for Richard only. Or anyone Richard says to talk to.
There has been many others trying to "ride" on the TiTAN's wave & band-wagon uninvited. TiTAN has been kind not to talk them away, give chance to young people, since they so enthusiastic and has been extremely linean but their kindness was abused.
Hence, practise the normal procedure, only talk to the boss Richard.
Althought I am a moderator here, but I will leave to China from tomorrow and will leave moderation to Tom = zth owner & Richard = TiTAN owner.
I have been a vivid TiTAN's user and supporter from day one. Although I've acted like promoting TiTAN to allot of other people, never once I went to TiTAN to ask for commission. I never get involve with pricing and dealings, all the people I recommend to talk to Richard directly.
