TODA Pillow Mount
TODA Pillow Mount
Ck™
TODA Pillow Mount
Pillowball top mounts are essential to a high performance suspension system. The spherical-joint pillowball allows for a much less compliant connection between the body/chassis and suspension. By stiffening this connection, the driver feels more connected and in tune with the vehicle and is able to make steering corrections with much more confidence.
The Standard Pillowball allows for camber adjustment on most vehicles, while the Advanced Pillowball will allow for both camber and caster adjustment. Being able to quickly and easily adjust suspension alignment is a critical part of race vehicle preparation, and if you’re serious about vehicle performance these high quality steel and aircraft grade aluminum pillowball mounts will definitely suit your needs.
TODA Advanced pillowball upper mounts are designed for the TODA coilover system and improve responsiveness for any application. These mounts allow for both camber and caster adjustment for the ability to dial in your suspension geometry to your needs. These mounts replace the stock rubber or plastic mounts to reduce flex and improve performance. The angle of the contact patch of the tire is changed improving handling when installed on the coilover.
TODA Pillowball Mounts are designed to work with TODA coilovers. We can not guarantee nor endorse the use of our pillowball mounts with any shock absorbers other than TODA shock absorbers.
Suitable : Civic FD
Year : 2006 - 2001
*While Stock Last & Limited Stock*
**RM380.00**
Serious Buyer Please Call / SMS
Contact : +6017 668 8171 -Ck
*Item Can Shipping To Any Where
*For Other Product Or Price Please Call For More Information.
RBP Raceborn Performance
