i got question too~
the HU is 3 RCA output....
if i wan use 1 amp..to power rear comp speaker.....but i wan direct control sub woofer....
but 1 amp oni coonect to 1 RCA output oni....
so the function of direct control sub woofer cant be use?
If you still want the direct sub control (from HU), connect the HU RCA sub out to your sub amp. The amp to power rear comp should be connected to the HU rear RCA out.
and usually how many watts does an amp required 2 run a single coiled sub?? and how many watts an amp required 2 run a comp?? let me giv an example... 300W enuf 2 run a comp and 500W enuf to run a sub??
Depends on the power ratings of the sub and comp you're buying. Look at RMS ratings when buying speakers, subs and amps.
will installing a e-xover cause hard time in tuning the sound?? becoz i saw one of my frends had hard time tuning his e-xover.. so this means tat e-xover is a need and pre-amp is useless lar??? can i know how much a moderate e-xover cost?? if i plan 2 install a HU, an e-xover wit an amp wit comp set while lefting my mono and sub to b installed later, izit okie?? i think ok lar gua, rite?? if i wan SQ, using 4 chan amp better or mono?? becoz for SQ, they recommend me single coiled sub.
I wouldn't say it's a hard time. It gives you more option to change the cutoff frequency. If you run passive, sound not nice , then cannot tune or minimal tuning of crossover side only. Like I said, the term pre-amp has been used wrongly. Pre-amp = anything between HU and AMP. E-xover is also considerd pre-amp. What you're referring to is graphic equalizer. An equalizer let's you do further adjustment to your sound. A good one should be around RM5xx plus? You can install step by step. Depends what your budget allows. If you want to wait also can. Once got the funds, can do one shot install and tuning. I do not have the knowledge to answer the rest of the question.
electronic crossover is the external crossover tat u need 2 buy it urself wat?? btw, can u tell me wat HU hav built-in e-xover?? CD2000 got or not?? how can we know if a HU got built in e-xover??
means tat go active is better than go passive?? like tat i dun need 2 buy a HU tat hav 3 RCA pre-outs d, rite?? ordinary one will do its job liao..
The HU manual or the manufacturer website will write down the spec. You can tell from there. I think the Pioneer P80 and those high end Alpine units have built in e-crossover. Even the Kenwood KDC-X5729 have a basic crossover (front & rear HP, Sub LP). One of the reason for a 3 pair RCA out HU is, you'll have front, rear and sub pre-out. Depends on your setup and plans, you can really go beserk by having front 3-way, rear 3-way and a sub rca to sub processor. The other reason for a sub RCA out HU is so that you can still use the fader and the sub does not 'dissappear' when you turn the fader all the way to the front.
Example system:
3 rca pre out (front, rear, sub) or 2 rca out (front, sub)
Front RCA to Front amp and comps. Rear speaker out to rear speakers (as rear fill only). Sub RCA to sub amp. When I set the fader to Front 12, the sound from rear can be heard in front, but really soft. The sub still pounds as hard.
If your HU only have 2 rca out which is only front and rear,
Front to amp and comps, rear to sub amp and sub. Once you play with the fader setting to play more to front, the sub can't hardly be heard.
if you only have 1 rca out connect to e-xover, you'll lose fader control. Once you change the fader to all the way to the rear, no sound would probably come out.
There's a lot of possible setup. It depends on what you want and what hardware you already have.
