timing tune with reset ecu
boyzone
2,000 RPM
hi, guys..
I will change my throttle body from 50mm to 54mm soon, so after I install , should I need to reset ecu/ grounded ecu to retune back my timing and ignition ?? how to grounded my ecu ??
pls advice .. Thanks :D
if u just want to reset the ECU..just disconnect the battery for a few hours...then plug it back..shuld do the job...
so after I setting everythings, if one day I gonna to change battery, that's mean I still need to re tune back everythings ??pls advice :D
i dont think u have to... unless u disconnect the battery 4 few hours...
half n hour or so wont reset yr ecu... trust me... done dat b4...:smile:
