there is some question need help
lbk182002
hi there
there is some question i need to ask
why is the component crossover always blinking yellow lights when i always open loud
is there anything will it spoild if i everytime keep doing it
can anyone explain it to me
thanks
some passive crossovers come with a small bulb inside, so that it takes up the extra power that would spoil the tweeter.....dont worry about it, its working..
if the bulb is overloaded then the 'extra' power will go to you tweeter.
Try not to push your components too much.
oh u mean that
if the bulb started to light then i better to reduce the voice izzit
if not the extra power will make the tweeters spoild izzit
just a sign for you not to push further. And the bulb does not know if your output is clipped or not.
if pushed too hard, either the bulb fail or you tweet.
