The Supersport, spearheaded by 999 Motorsports, Thailand, centers on a tubular framework. Designed to meet the requirements of race circuits; structurally, the vehicle consists of a fiberglass body and dashboard all wrapping a spaceframe chassis, are the leading features of its cabin.
The sleek Supersport devised for racing, derives its power from a Ford Ecotec 2.0L 4-cyl Turbo, capable of generating 300bhp and 258 lb-ft of torque. The engine is centered in the middle and transmits power to its hind wheels through a uniquely devised five speed sequential transmission.
Though nothing official was stated about its speed and performance, the lightly weighted racing vehicle is expected to deliver a speedy show. With only nine hundred and fifty kilos of weight, the sleek and slender racing car has a long way to go in the racing arena.
Technical Specs
Type | Supersport Mid engine rear wheel drive |
Chassis | Tube space frame (Steel 4130) Aluminum powder-coated panels |
Bodywork | Fiberglass / Carbon Laminated windshield, headlights, tail lights, adjustable rear wing, rear diffuser |
Engine | Ecotec 2.0L 4-cyl. Turbo Max. power: 300 hp at 5600 rpm (225 hp with endurance ECU) Max. torque: 350 N.m. Racecraft radiators and air water intercooler, stainless steel exhaust line and mufler |
Gearbox | 5-speed sequential Limited slip differential |
Gauge | LCD dashboard, programmable multifunction display |
Front/Rear suspension | Double wishbone, adjustable anti-roll bar |
Shock absorbers | Rebound adjustable |
Calipers | Front: 6 Pistons Rear: 4 pistons |
Brake discs | Front: Ø 320 mm Rear: Ø 285 mm |
Wheels | Front: aluminium monobloc 18x8" rims Rear: aluminium monobloc 18x9.5" rims |
Tires | Front: 21/65-18 Rear: 24/65-18 |
Wheel base | 2460 mm |
Front track | 1580 mm |
Rear track | 1540 mm |
Length | 4210 mm |
Width | 1850 mm |
Weight | 950 kg |
Fuel cell | 55 liters |
Safety | Extinguisher, 6 points harness, collapsible steering column, crash box |
More info: http://www.999motorsports.com/
It's all good tho...
