TEIN EDFC Adjustable Unit
Timeattacker
WTS:-
* TEIN EDFC(Electronic Damping Force Controller) Adjustable Soft Hard Adjustable,
* Black Colour,
* Compatible With Most TEIN Absorber;
* Used;
* Original from Japan,
* Still Working very well,
* Complete with Harness & 4unit of Stepping Motor.
Description: EDFC Control Unit:-
* Compact 1/4 DIN size
* 3 Presets for Quick Adjustments
* Separately adjustable for front and rear
* Ability to use the switch between 16 and 32-way adjustment
* Illumination for ease of use at night
* Variable Illumination control
* Variable Volume control
*EDFC Motor Kit and Wiring Harness*
* Sealed rubber motor cover for improved protection
* Decreased stepping motor size for use on more applications
* Complete harness with female/ male connectors
* Extended wiring harness for ease of installation
*EDFC Strut Kit*
* Uses a stopper bracket to eliminate tangling of EDFC wiring on strut type front suspensions.
* Tangling is caused by the strut suspension design which rotates when turning the wheels. Without the Strut kit, the EDFC wires will become tangled and may break.
ATTENTION:
One of the Motor Control Unit are FAULTY is on the Rear Right Hand Side.Others are Working FINE.
******************* RM380 ****************
Interested can direct contact:-
016.964.5648- Anytime
Thanks For Viewing
