Taking Order For New Custom Camshaft
synchron
Taking order for custom new billet camshaft. Made by chilled cast billet, brand new, no regrind and can custom any profile that you want.
Price will RM 2100.00 for 4age 16v and RM 2400.00 for 4age 20v. Need to mention about turbo or na because there is a different between them. Camshaft will be made in USA.
It will take about 2-3 months time to arrive.
Other stuff that I am doing is 4age 20v throttle body fitted into 4age 16v. Price will be at RM 1800.00. Adapter will be made by alluminium billet. Very light weight and hard material. Programable ecu's is optional, because they r normally not required since they are not running on afm system. Bracket will made in Sabah by Mr. Chin Lee Kun.
Third is the supercharger kit for 4agze which can push up to 200 hp from a
Stock supercharger engine. Price will be at RM 7000.00. Still in R&D process for the brackets. Bracket will be also made in Sabah by Mr. Chin Lee Kun.
A few other R&D which is still in process is AFM 20v to DLI MAP 20v. Trying to solve the over fuelling problem currently without using any piggyback system. Kit consist of ecu, crank angle sensors, ignitor, wasted spark coil pack and new plug and play wirring. Cost will at 1-2 k range.
I'm quite interested to know more regarding this product:
However, I'm not quite clear on what does the RM1,800 price tag includes, will it be only the adapter? Does it includes the 20v ITB?
For comparison purposes only, here are a list of products from other manufacturers:
1. RS Chita (Japan)
http://www.rschita.gr.jp/type2-004.jpg
http://www.rschita.gr.jp/4renmani_type2.htm
Includes:
- intake manifold (4 vacuum pressure 'nipples', remove nipple 1 for brake master?)
- 8 knock pins
- aluminium vacuum collector tank (attached to nipple 6?)
- long fuel hose
- vacuum hose (4 φ 6 φ)
- 2 installation bolts (7 + stud bolts)
- gasket (for 86 or 92 heads)
- brake master vacuum extended hose
- 6 angular wrenches & bolt set for throttle position sensor installation
- direct throttle linkage set
- water outlet
This set sells for Yen 69,000 including tax (approx. RM2,433.30).
2. Techno Toy Tuning (US?)
http://www.technotoytuning.com/media/t3/products/itb_adapter1.jpg
http://www.technotoytuning.com/t3_site_pages/products/itb_adapter.html
Includes adapter plates only.
Sells for USD? 249 plus shipping (approx. RM946.20).
the adapter will be just like the techno toys one's. The kit will include an used 4age 20v four throttle, ulluminium adapter. gaskets, air hose, bolts and nuts. We are tyring to make our system plug and play.
You will need pay import taxes and transportation if you r ordering from overseas.
The RS Chita looks great but they dont have any throttle bodies with it. Try to add the price to purchase the throttle bodies, transportations and also taxes in Malaysia.
TechnoToyTuning shipping is only in the states if i m not mistaken. I dont see that they include throttle balancing holes and pipes. The car will not idle without them. You will need to drill extra holes on the adapters. That is the price just for the adapter. You will need to ship and pay taxes plus sourcing all the parts yourself.
Other than our throttle kits the best bet will the TechnoToyTuning. You will have the chance of getting the same price as ours.
I cant post any pic because there is a 50k limit and i have also avi on how it is test runs. Email me if you like see pic and avi, 7MB all together.
[email protected]
That's great. Will customers be able to buy the set without the ITB? If yes, how much?
The cost will be more than buying a set actually. Selling at RM 1500.00.
There is no warranty for stuff which we sell not in a kit form. For example:- we wont be respondsible if the throttle doesnt fit the adapter. We test every sets before we sell them.
It is quite interested to see your posting. Can the Blacktop 4A GE 20 Valves install in SEG AE111 1997 Auto Transmission? Your engine come with the gearbox? if include installation cost, how will be the charges?
