sw20 power steering problem
yn_hell
hi, need some help from the sifus.
my power steering went off few months back, it was fix (the electronic board).
but recently, it went off and on again, as in sometimes when i start the power steering went off, then when i start the car again after few hours, it went on again. anyone know how shd i fix it?
thanks
iexit knows. iexit advuse pls.
I think it is the relay getting dirty. Plug the key in and out making full turns each time for about 20 times, real fast. It should clean it.
i never know you can clean a relay that way! :rofl:
Soff is quite right... as the shape/edges of the key are worned after some time and therefore the power steering contact point fails to detect the key and does not activate.
You will need to insert the key in and turn to the ACC position several times to make sure contact is made. Repeat until it is resolved failling which you may need to replace the key ignition chamber.
