Suspension Sagging?
Replay
My car suspension seems to be uneven now, I'm using eibach springs and using oem kayaba shockers on my sgti. I've changed the setup above about a yr plus ago.
Noe it seems that the front end driver side of the car is lower. Anyone have any idea wat could be the prblem?
Is the absorbers gone?
to check your abs... simply push down hard and see how many times your car bounce. if more than one or one and half. then its time to change that abs
to really check if its sagging one side or not. park your car on an even road or a concrete parking lot area (shopping mall) and use a measureing tape. measure from the top of the wheel arch to the ground. if both front are same (left n right) then its ok same as the rear.
so if all check and no discrepencies... confirm your eye sagging and not your car.. hehehehe:biggrin:
