SuperPro Polyurethane Bushings set for Mitsubishi Triton 2006 onwards
G221
1. Steering Rack & Pinion Mount Bush - Power Steering (5Bush/2Tubes)= RM330
2. Front Control Arm Upper - Inner Bushing (4Bush/4Tubes) - Do not remove original shell as it must be re-use = RM600
3.Front Control Arm Lower - Inner Bushing (4Bush/4Tubes/4Washers) - Remove original shell before fitment = RM650
4. Front Sway Bar Mount Bushing (2Bush) - Measure bar diameter 25.4mm = RM150
5. Rear Leaf Spring Bush (12Bush/2Tubes) - SPF0192Kx1, SPF0187Kx1, SPF1983Kx1 = RM400
012-2047338
KL
Postage RM20
