Supercharger Oil
Adeen
2,000 RPM
hi all....
i just want to ask what oil do we use for supercharger oil and how much is the cost...??
i've tried the search button but somehow it came out with nothing....
bro 7heaven has said that 134 oil can use(aircond compressor oil)...is this true..??how much is it usually..??
because i've asked this spare part shop....he said supercharger oil for half a litre is RM100+.....
that sounds too expensive for me....and he made a joke saying something like, "supercas maa....minyak kene cas jgk, itu harga pon cas"....crap...
positive feedback would be most helpfull...thnx in advance...
heheheh...bro7 rite..me before used dis oil too....can get it at sparepart or air con shop...but..before what oil u used bro?....Beware...u must always check dis oil...kurang kalu ur sc12 will not last longer..
ui place me on table pulak...
yea 134 oil is ok for compressor, since 134 oil also use for aircond compressor.
like nnik said u must always check the compressor oil, coz it easy to kong once the oil not enough, better check it every month la...
true...supercharger oil at wing hin, jln loke yew, last time I bought was about rm98 that was 1 1/2 years back...but usually every 6 mth... u check...one bottle can last more than 1 year for me.......
sorry la bro 7heaven for putting u on the table....
since i've only seen u commented on this oil before....
never seen others comment on it....
i check it every week oso la....it's at low level already....
but my uncle's supercharger oil, 3 years oso not that much depleted...
never mind la as long as i can help u up ok lo...
no need to use that pricey oil also nvm la, just use 134 oil oledi enough...
many of my fren also i ask them to use 134 oil, so dun worry la, wont have problem 1... but if u got damn much money then u can try the pricey oil lo hehehe...
may be ur mech also never check it for u when u change the engine, try to refuel back and have a check again after a month....
if the oil less till low level again, may be ur compressor kong oledi....
hehehe....the supercharger just bought lor from a buddy of mine...
it has been at low level since i got it a month ago...never decrease even a bit...
so, want to try to refuel it back....
how to know compressor kong or not...??i still can feel the power of the sc12...
if u still can feel the power then it haven kong yet lo...
got sound come out from the compressor or not? kinda bearing sound ah...
it got a needle at back side of the compressor, like engine 1,
engine 1 is pull 1, but compressor is use twist 1 like screw...
if ur hand "fat" then will be abit hard to open the needle hehe....
no sound whatsoever come out from my sc12 unit.....
got this one time, this LE sc12 unit was very loud...kinda like that bearing sound from kancil turbo.....i thought his s/c mod kaw kaw lor...hehehe....
the supercharger oil is kinda behind the engine....
mine is yellow in color the screw....
if the charger sound like "klek klek klek" that mean bearing kong oledi....
if u got boost meter then will be better lo, normally it will bost till 0.6bar or plus, if use oversized chager pulley the boost will be 1.0bar plus...
all in yellow colour 1.... unless u spray it to other colour kakaka...
ya it still work, just add boost meter only ma...
if ur boost lower then 0.6 that mean ur compressor kong oledi....
