Super Strong Magnet for Car Care - Space Technology
siowwf
Intro:
- A space technology from US that converted into car care product
- It is a high technology magnet with super strong magnetic power
- Magnetic power will only start reducing if the temperature exceeds 180 degree Celsius compare to normal magnets of 60-80 degree Celsius
- Very carefully shielded without affecting other electrical equipments
- Filters tiny particles of up to 2 micron size that oil filters can't (don't be surprise!)
To Use:
- Clip on the oil filter to ENSURE tiny metal particles of up to 2 microns are not recirculated into the engine
- Can be reused after oil filter change (one-time investment)
- As easy as that
Price:
- SS250: RM209: For 2.50" to 2.80" diameter filters: Pull force up to 34.01KG
- SS300: RM229: For 2.90" to 3.40" diameter filters: Pull force up to 40.82KG
More info:
Call : 019-302 6600
Email : [email protected]
URL : www.kedaiauto.com
SS300 is going for price increase by next wednesday.. probably will be rm240
Pls explain, how your product is more superior that the cheaper magnetic oil drain plug?
Hi risyia,
Please find the advantages of Filtermag compared to the normal magnet drain plug as you mentioned as follow:
1. Filtermag is made from Neodynium (a rare-earth material, the strongest magnetic material)
2. 100% will not affect other electronic parts (as it is properly shielded with Zyxel - space tech)
3. Magnetic power reducing only @ 180 degrees Celcius & above (normal magnet: 80 degrees)
4. Uses unconventional filtration method (grab all the metals at Oil Filter wall, throw after replace)
5. Able to grab metals as tiny as 2 microns
6. Reusable for lifetime
This is a product widely used in Singapore currently. It suits cars and even industrial machines for the oil filtration purpose.
:wavey:
