Suitable turbo for 13bt
maxezin
Hi dear Bro's ,
Please advise whats the best turbo to be mated to the 13bt mild ported engine .
Its mainly for street driving and 30% of whacking .Looking at 350 - 400 hp turbo .
As the ported engine already got no torque :P i ll nned a responsive turbo for street driving.
Currently using the stock turbo back as the big turbo im usung is damn laggy ,no good for Singapore roads :)
Any ideas plus turbo a/r size.
Thanks
There are a few turbos to choose from Hybrids turbos ( using stock turbo turbine side and a T04 side compressor housing) Full T04turbos, GT28 series, RX6 turbo.
A good choice for your requirements would be a T04S or T04E. Budget turbos with still good power to be made. Of course, with the proper tuning and up-graded systems, ie, fueling , spark, drivetrain to support that power are needed.
That turbo were you using before ? What rpm did boost come in ? full boost@ what rpm....
http://www.turboneticsinc.com/downloads/techdata/TurboMatrix.pdf
here is some help for ya
hey , thanks for the reply .
The original with to4 housing i ve ever tried,its a very good resonsive turbine but not much of a high end power turbine.
OK now about the A/R size?what will be the most suitable?
ok then , will try to source for it.
Anyway , any idea whats the A/R size of the standard hitachi turbine?
Thanks
Try looking up Knightsports. I hear they have a bolt on turbo unit which bolts on directly to existing hardware. No mods needed except maybe for a new ECU. Good for 300-ish HP. Not sure of the specs yet.
