Suitable Engine
strontium_bismuth
hello guyz , i just want to know what are the suitable engine that can be used in Toyota LE AE80 . Right now , i only know the Levin 4AGZE would be the best suited in this chasis .
What about MMC engines ?GSR , Vr4 engine or Mivec that can fit in this chassis ?
Thanks guys .
p/s : I want to change new engine .
What about MMC engines ?GSR , Vr4 engine or Mivec that can fit in this chassis ? https://www.zerotohundred.com/forums/style_emoticons/default/dry.gif alt='dry.gif' />
Thanks guys .
[snapback]918159[/snapback]​
what for wanna change since the 4AGZE also a very good engine. Go Toyota MR2 VVT-i if u wanna like mivec then if u want turbo then take the MR2 Turbo version then if not can go for supercharger or 4 throttle. so many engine from toyota u still 1 go for other type oof engine i also dunno what to say. if u really insist wanna try go for SR20 turbo.
go for any of the 4A engines as long as they have an A. a rebuilt 2A, a rare 3A, the usual 4A, 4AFE, 4AGE 16 valve or 20 valve, 4AGZE.. all up to you. these are suitable and affordable engines to put in the uncle clunker.
the best engine for the AE80 is the one Toyota put in them, the 2A-L, 3AC, 2E, 4E.. so ask yourself properly. u want the best engine in terms of racing your ass off, the best fuel consumption, or the best in noise?
Dont even think about putting any ridiculous engines in that car if you're making a daily driven ride. since your question suggest that you're new, forget that dream about a 3SGTE, GSR, Mivec etc. You'll regret it, your pocket will regret it, and the car may, MAY only run well for illegal races. putting any engine be it the 4AGE without thinking about the 20+ year old chassis, body strength and suspensions will only make the whole car die sooner, if you dont kill yourself in an accident first. You're excited about a transplant, fine.. just dont overdo it. i know, you asked nicely. Well now you know.
go over to the toyota sub-forum. on the top of each page just below the zerotohundred banner, u will see 4 links at the right:
help search members & calendar.
click on search. a new page will open.
in the Search keywords section, type 'AE80' or 'LE' or 'AE82' (without quotes) in the "Search by Keywords" field.
under the "Search Where" section, make sure the "Toyota" subforum is selected (its a branch of "Makes")
Click on "Perform the Search" button at the bottom of the page.
browse thru all the search results and read all that you can from the threads.
happy learning, put some effort and have a nice day.
toyota muz put back toyota engine......ae80 put in ae92 4AgZe powerful enuf for ur car chassis.......Mr2 engine is very good but it is not ao worthy to put in AE80...lots of modification meed to be done to strengthen ur chassis in order to run stable n smoothly.....
