Sudden increase of terrible vibration
kher
1,500 RPM
After changing crankshaft pulley tat day the car has very terrible vibration when the gear is engaged at D.
The vibration is from the place i switch on air cond til all the way to the gear knob.
Vibrate til coins also jumping.
Any relation between this changing pulley n causing vibration? Or something is not in the correct position?:frown:
Timing is ok...800-1000rpm
sure salah install wan ler.....
bring it back and check ler..
maybe never pasang properly....
me last time also like this.....lucky i always check the car b4 i leave the garaj....
U mean u also get vibration after changing the crankshaft pulley like me?
I also notice it is not so obvious after the engine has been running for some time.. Cold time is the worst 1...
rev till 3k ..no vibrate....
idling time.or start the car vibrate....
drive after awhile no more vibrate....
go back and check la.r.
pulley kong again?
Wa.... exactly the same wor as wat u said.
k...Tmr go check again.
Pulley kong again? Ask them pay bak another 1.
2 reason..
either kong again..
or they never screw properly...means never masuk to the square nut deep inside...hopefully if loosen..the square nut for the pulley never haus...if haus liao...i dunno how..change the whole crankshaft leg?
u drive satria wan rite?
like this...
Tmrow u ask someone to start the car for u while u watch the pulley and the belt..when u start the car..if it shakes...
confirm ..kong or the pulley problem..
why did u change the crankshaft pully in the 1st place. for my galant, i had to change the pully after timing belt snapped. its purpose is to avoid valves bengkok.
as the engine is not so smooth itself, no difference can be felt.
p/s maybe u shud change complete engine laa kher. 4G63 DOHC ke. :D
