Stuff for sale guys....
DinNismo
Sale stuff...
1) HKS airfilter with HKS hose n adapter for RB engine..Taken out frm RB25det
comes with brackets (no filter element) RM200
2) Sheepdog blow off RM200
3) BOXER (field) aftermarket ecu for RB20det RM550 nego
4) R33 Tien adjustables (front) SOLD
5) NISMO strut bar for A31 cefiro SOLD
More stuff n pics will be up soon..
Pls PM or call 019-3658124 (din)
hahahahahhahahahhaha............that diff laaaa......itu pun lu tak tau kaaaa? Diff! hahhhahahah Diff is the brother to doofus! .... Diffus!
hahahahaha......dang, how did you know it's white?!
chriiz18, just ignore me. I was just being cheecky,that's all.
ECU? you have to try it out cause when the jap got it installed on his car it was tuned to their fuel quality,their weather, and the cars application.
I have tried too many ECUs on my car before and concluded I have only 20% chance to get an ECU that will almost work for our car in MY.........unless you get an Apexi product those are the safer bet as it gives you the adjustability to suit your car and application.
Alternatively,try the fuel regulator,stronger fuel pump,injectors and play with the CAM's timing.
I was runing stock ECU with auxiliary support system( the 5 button AFC) and never had a problem of lean mixture.
Hope that helps
allo.. 5 button AFC is your pass tech
SAFC also is no eye see for you
by the way..
how the ride after fitted with twin GTRS and cam ?
cmng..........the GTRS got problem laaa so had to take ém out for replacement and dueto that the CAM no mood to install them also........your Altezza sudah mali ka?
chriiz18, no problem. It's like mahjong, you need to pay up your dues once in a while heh heh heh.
Devious
Altezza still in progress
HKS Japan said they waiting for the 6 speed sequential gearbox arrive
nabeh.. GTRS.. throw it la
put twin 3037 la
