Street & Performance Brake Upgrades
drexchan
2,000 RPM
IMPORTANT REMINDER: Read this post thoroughly before you ask. When you are calling/SMS, kindly introduce yourself (name, forum, car model).
http://www.autoworks.com.my/images/logo%20animated.gif
http://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc4/62847_155090824513494_100000377312513_336691_4135783_n.jpg
IMPROVE Cross-drilled & Slotted Disc Rotors
Designed and engineered to comply with all major OEM standards.
Helps cleaning brake dust and improves ventilation of gaseous product emitted upon braking. Works on any brake pad that works.
IMPROVE Formula 600'C Semi-metallic Pads
Ideal for high performance street use where intermittent and hard braking is required.
Performs moderately across the temperature range, bites well once heated.
Light dust. Moderate pedal feel.
RAPIDSTOP Performance 550'C Semi-metalic Pads
Ideal for hillroad drives where frequent intermediate to hard braking is required.
Performs well across the temperature range. Mild warming up is recommended for optimum performance.
Normal wear rate and slightly dusty. Hard and progressive.
PUMATEC 500'C Ceramic Pads
Ideal for street use where smooth braking is usually all you need.
Protects rotors and reduce rusting. Soft and profressive pedal feel. Dust easily cleaned.
PUMATEC 680'C Ceramic Pads
Ideal for street and light track use with exceptional bite at high working temperature.
Warming up is necessary to safe use. Moderate pedal feel.
INSTALLATION: Provided
WARRANTY: wear & tare items thus no warranty, but can privide free inspection upon request.
CALL: 019-359 3909 (Drex)
Click here for Google Map
NEW!!EA Autoworks Fan Page
any DRILLED AND SLOTTED DISC ROTOR for toyota starlet ep82......???
looking for a pair front.....
DRILLED AND SLOTTED DISC ROTOR for wira aeroback 1.3 front....how much + installation....hw much is it......
Greetings sifu drex,
enquiring for waja rear pair only..pls pm when ur free. tq
Bump: Greetings sifu drex,
