Straight Flow VS S-Flow
ipin
Any review on this? Heard someone said AT just nice with S-Flow setup compare to Straight Flow exhaust! Plan to install straight flow (HKS Silent Hi Power) with more 'garang' sound (EVO sound :biggrin:). Mind to share the pros and cons...
I'm using straight flow. Straight to the point answer:
Pros:
- More responsive high-rev
- Power don't deep after 5500rpm for stock engine + stock TD04
- Less turbo lag
Cons:
- Loose low-end torque.
- Car felt slightly hesitant on traffic jam stop and go. (before turbo kicks in)
If you're planning for stage 2 mods and above, then go for straight flow. Else s-flow works perfectly for mild mods.
OIC... thanks for response... Then, hold first la the devil project! :smokin: Stick to S-Flow first la before mod to TD05, high cam or maybe 2.2! :tee::tee:
---------- Post added at 04:37 PM ---------- 6 hour anti-bump limit - Previous post was at 04:12 PM ----------
stutzedward, have u record the sound after u installed evo6 cam? any changes? hi-cam, sound nice!
