Stock alarm+immobilizer, turbo timer
wfc31
i am having ???? regarding how the stock alarm+aftermarket immobilizer work together with turbo timer?
let say now i have stock alarm and immobilzaer in my car, as normal i arm & disarm when leaving & entering car.
but when i install a turbo timer for my turbo car, when i leave the car and arm the alarm while the engine still running during the timer count down, will the immobilzer cut off the enginer?
It depends on how u wire ur immobilizer and turbo timer. If you wire them parallel the turbo timer would still function even though the immobilizer kicks in. If you were to wire them in a series, ie from immobilizer to turbo timer, then ur turbo timer would not function. Just a matter of how the wiring is done. I presume that ur immobilizer is just a basic starter motor immobilizer right? Not those that immobilize the ECU too. I guess even with ECU immobilizer, it can still be done, but the wiring would be more tricky.
WFC31 :- My car got stock alarm and stock immobolizer...I also got turbo timer even my car dont have turbo :)
Well, the man that install timer to my car quite expert....My immobolizer activate once my timer finish countdown....Need to put relay...
U can go one shop... beside N1 in sunway....Ask Ah loo....I satisfied with his work...I drive vios
