Steering runs..
DeadManWalking
Need some help guys. My car don't have power steering. my problem is when i turn left then steer back straight my steering is not centered, need to steer back right a little then only centered. this goes the same when i turn right, need to pull back left then only centered. Some say change the rubber bush/pad at the steering box and at the allignment bolt/nut. but i duno what it's called exactly. Is it true? thanks for all your help..
yeap... send to workshop and do allignment as well.... coz workshop as the computerised thingy to make ur car allignment exactly straight...
before that, check ur tyre pressure as well... ur steering cant turn back to centre position mayb coz pressure too low... if tyre pressure ok, go workshop... :)
