HI everyone,
could you please share thoughts on replacing stock brake hoses to steel braided hoses
would there be any immediate difference of better braking ?
Depends on the age of your stock brake hoses.
My old Wira was 7 years old before I swapped to steel braided hoses and the swap was because the hoses expanded a lot each time I pressed the brake pedal which resulted in unresponsive or spongy braking. So in the case of an old worn out hose swap - yes it's useful.
My Myvi on the other hand had it swapped out when the car was just 3 years old and that made no difference whatsoever. The original hoses were still firm and solid so comparing that with the steel hoses didn't really make much of a difference.
There's something you have to be wary of with braided hoses, the wheel arches are the dirtiest parts of the car, stones, dust and all might get stuck between the braiding and over time may cause leaks. You don't want your brakes to leak. So either look for hoses that have a protective coating or keep your wheel arches clean. My Myvi has been on the hoses for 5 years now and my Wira's one is still going strong (cars already sold).
Yup, can feel the difference. Better response for sure. Cheaper option is to cable tie the stock rubber brake hose![]()
of course there is better response.
for normal driving, like in KL traffic, start-stop situation dont really feel the difference.
Spirited driving and stopping can feel abit with those hoses.
BTW, what brand you are looking at?
tx, being hopeful
---------- Post added at 10:34 AM ---------- 6 hour anti-bump limit - Previous post was at 10:33 AM ----------
tx ken yeang,
I do not have any brand on mind.
what would you suggest ?
the cable tie does work on cars but not suggested to use on performance cars, for wira, myvi, viva etc...then ok la.
Some say SuperCircuit, but for me I use Pro-RS im satisfied. Unless yours is performance car like your profile photo. Then many seems to suggest Goodridge but some claim Pro-RS is good enough.
without test driving the car, i cant say what exactly wrong.Hi Izso,
appreciate the insight.
the reason for me to opt for the steel braided hoses is because my brakes are biting very well only during the first few minutes when I move my car after a cold start and then after upon heating up, the brakes aren't biting much or well
---------- Post added at 10:33 AM ---------- 6 hour anti-bump limit - Previous post was at 10:32 AM ----------
lol !
I wouldn't use cable ties ever on the hoses
I would not use cable ties :)
---------- Post added at 11:57 AM ---------- 6 hour anti-bump limit - Previous post was at 11:56 AM ----------
this is for my proton satria 1997 model. noted on PRO-RS
between rubber or braided hose : it is much more practical to have high temp tolerant brake pads or progressive brake rotors.
I've changed mine to braided from Pro-RS and the only benefit there is : static braking pressure on the pedal. No spongy feels.
That spongy feels you get from rubber hose is not much of an issue in braking unless you're doing some very serious racing needing you to dump the brake hard very late before cornering or evasive braking, VERY FREQUENT. i changed mine for the 'suka-suka' factor, curious with braid hose functionality, voila... not much contribution compared to rubber hose. Even if it can stand high hydraulic oil pressure : if the pad or rotor went overheat... you lose the brake no matter how much you pump the pedal or get standing on the pedal.
Concerned with braking performance? Brake pads and rotor. Or bigger brake kit.
Hi Izso,
Hi Izso,
It's a possibility your brake hoses are expanding. Easiest way to tell is to jack up on side, remove the rim, have someone start the car (neutral) then press the brake continuously while you observe the hose. Any sort of expansion is bad. If you do see any - steel braided hoses will help you.
Otherwise it sounds like you have a brake pad issue.
Don't just keep focus on brake hose...its not the 'everything' of brake system...
Do check your master servo (weak cylinder, diaphragm, vacuum connection (any leakage)) follow by caliper.....
