Srs Warning Light
artnet
1,500 RPM
I read from website saying unplug the yellow connector
with two grey wires. and wht MES(memory erase s...)
but i'm finding difficulties of removing the yellow socket.
anyone know how to remove it? my fingers still in pain...
darn.
it is very tightly connected ... i'm not disabling it..
i don see anything to press. most of the sockets there
having a clip one. but it doesn't.
i wanna unplug and erase it's memory... if not it will
keep light on... coz the damn mechanic unplug it's
fuse and put onto the brake light fuse.
then i ask him why my srs light on. he said then have
to check loh. come tomorrow.
i think he wanna cheat me... so not going to see him.
found solution on net. so wanna try out myself. most
of the mechanic out there isn't trustworthy...
looking for 1 lerrrrr mie........i should buy from izam last time huhhhhh..huhhhh...
artnet, come here and i'll ldo it for u....kehh kehh kehhh...
looking for 1 lerrrrr mie........i should buy from izam last time huhhhhh..huhhhh... :(
artnet, come here and i'll do it for u....kehh kehh kehhh lat time i do it myself including dimantling the airbag evrything........but definitely difficult ;) ;)
mechanic????? emmmm most of them just try and error and depends on their experience....kaki chong jugak.... :angry:
gosh... if it lights on... dunno still function or not mah.
so better to do it the corrent way. erase the error first,
if it still light on back... something wrong liao.
i'm from the east malaysia dude...
got from the net .. happy DIY ing ..
Answer
How to reset your Honda SRS light works on most models of Hondas
Directions for erasing memory on SRS light, but this procedure only works if all problems causing the indicator to be "on" have been corrected.
1st Obtain an 'SCS Service Connector'. You can use a speaker harness for an older Honda, which you can buy at any stereo shop such as Radio Shack, Circuit City or Best Buy. Cut the wires and loop them together. Or use a paperclip but that will make it a little more difficult, because you have to connect-and-disconnect it a few times quickly. 2nd you need to find the MES (Memory Erase Signal) this is located in or by the fuse box it is a yellow connection, remove it from the fuse box and jumper as described below. If there are 2 yellow connectors at the fuse box under the drivers side dash, look for the one with only 2 wires. That will be the one.
MES Plug is usually in or by the Fuse box.
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
If this does not work and the light stays on then something is still wrong in the system.
Maybe the wire connection under the drivers seat or a fuse or bad ground or a bad clock spring (clock spring is under the driver side air bag).
Again, this procedure works only if all problems have been corrected. Good Luck!
hows the yellow socket look like ..
Originally posted by artnet@Apr 16 2005, 12:02
yeah, this is wht i've been told.
my problem is i cannot get the yellow socket out..
https://www.zerotohundred.com/forums/style_emoticons/default/sad.gif alt='sad.gif' />
[snapback]902442[/snapback]​
hard to describe. other soket got clip... very easy to remove.
but this yellow one doesn't has it. dunno how to remove.
hard to take pic too... coz very dark and tight area.
sigh, nvm la... just send to mechanic liao i guess.
