SRS airbag light ON
did you put the sensor connection back properly?
srs light means airbag faulty.. or maybe in your case.. no airbag detected
actually the foreman are the person who disassemble it, but as i saw its oni 1 socket n 1 earth wire within the steering. Thats all, n he didn't touch anything else. Any solution......?
u need to bring it to a mechanic to fix this..........
if u are around PJ try avantgarde mechanic at tmn bahagia, my fren had that same problem before this also...now solved
what car?
new car like city require to reset the srs using computer...
if old one like ek4, check the wiring itself. mine oso same problem before.
but finally solved bcoz found one socket not connected to the fusebox...
