SR20DE Modification
Ethan
Does anyone have any experience or insights into how an SR20De should be modded? I'm thinking of superchargin it instead of turbochargin. My reason for it is that because it is NA, it has a higher compression ratio, therefore by superchargin, i can get a smoother power output, and hopefully enough horses gained.. Im just putting together a plan as what kind of mods I should do, whether it is worth modding my S13 Q to drift or just change car..
Any comments would appreciative..
Thanks
Dude... u know what's supercharger anot? Supercharger and turbo are basically the same thing... they're both forced induction and they both require low compression engines. The only difference between them is the driving force... ie: how the turbines are spinned... turbo uses exhaust gases, where as supercharger is belt driven... they both produce boost.
refer to this article for difference between turbocharger and supercharger:
http://auto.howstuffworks.com/question122.htm
Advice... transplant SR20DET... else if wanna play n/a.... try going for 4-throttle. Think i've seen quite a few 4-throttle SR20s on mags before.
hope my posting helps...
My fren use s14 engine,of course original,can beat the wira GSR 1.8 with 1.1 bar...civic B16B...........
even can drift
car is 910
yea. i know of superchargers n turbochargers, but then i read somewhere about superchargin a NA engine so that you won't get the lag that turbo gives. Also i vaguely remember something about the high compression from NA engine making it more suitable for superchargin instead. Any thoughts on that? I have to say that i'm no expert, but i'm still learnin :)
and as for the 4-throttle..could you explain more? as this i don't know what it is. hehe..
=-þ cmng,,,,,, cmng........
wei wei how's Hyper Orange Sunkist......
4 throttle best lah wei... who wants VE if u're gonna run such radical cams kekeke....
U have to drive one to realise the benefit in throttle response and induction roar with individual throttle bodies.
cmng said:
4 throttle on DE not much deal
put SR20VE head on it.
Okay.. you guys are gettin too technical here.. :p
I Know that a NEO VVL SR20VE has 187HP, whereas the SR20DE only has 140HP..
but u suggest just changing the head. This changes the compression doesn't it?
Or to use this head, I'm looking at having to bore the cylinders?
I'm getting really confused.. Could you explain more? thanks..
Is that what you have done to your GTi-R? but doesn't your car run on the SR20DET?
Not sure if its kinda like mitsu mivecs where everyone just bolts on the head to a 1.6 or a 1.8 coz' same block design... so its kinda direct fit. So cross ur fingers and hope its same block design also lar... hehehe.
4-throttle going to have damn good throttle response man! But be prepared to spend more on petrol also lar... needless to say with more power comes higher fuel consumption.
Supercharging and turbocharging has no difference lar... its about how high u boost only. They both require low compressions to boost higher.... else internals will start to fall apart.
even can drift
car is 910
I'm going to assume its an SR20DET... which would then make the odds unfair comparing a 2.0turbo with a 1.8turbo or a 1.6vtec.
If its n/a... as much as i'd like to say anything's possible... it really seems pretty impossible since u said its stock.
SR20VE head on 20DE
is common thing done at japan and US nowday
Vic..soonnnn
SR20DET is sucks
same like DE and VE
4G63 and honda is best !!
Save the fuss and get a SR20DET. Although the DE and DET parts are interchangeable but the cost to change these are costly thus transplanting the whole thing is easier and cheaper...
just turbocharge the NA motor.. higher compression but if tuned well, shouldnt be a problem.. just dont go crazy with timing and boost..
heaps of cars in drift both here in Oz and in Japan running SR20DE+T.. if it does end up breaking (which it will, but think of all the fun you'll have before), then step up to an SR20DET..
have fun going sideways
of couse is original lar...
ok...the secret is the final drive
ratio.....secret lar
n with a fuel pressure regulator.
even the bore x stroke of piston, compression is original
I sure the 1,2,3 gear can beat those car...... :D
even can drift
car is 910
when you say beat.. what do you mean? 0-100km/h? downhill? what sorta power is the SR20DE putting out? i dont think its that much even with extractors, cams, etc.. unless u added NOS.. but then it wouldnt be NA and it wouldnt be *that* much..
share share :)
trust me lar......saya tak ada bohong bunya....
of course 0-400m lar....saya pun ada dekat situ
even tis car can kejar A31 RB20DET AT
our fren laurel 200L RB20DET AT with 3.9 final drive cannot kejar
tis car final drive a little lower than B18C 4.785
even we dyno tis car, on wheel is 140hp
tambah lagi ada variable timing,torque pun lebih tinggi than VTEC...original pun 20n/m
our fren s13 SR20DET boost 1.2kg/m....ah ini kita tak dapat kejar lar
