Fluffy said:its the joint at the end of the clutch pedal...
no lubricant..so produce irritating noise.hehe
just need to apply sum oil at the joint..
xcheong said:its most probably worn clutch cable.
replace it.
also check if ur clutch its too hard to step.
if its too hard, u might need to replace your clutch.
if u dun replace it, u will damage ur firewall and that's quite serious.
cuz the clutch cable run thru the firewall from ur pedal.
i experience it already. and its quite costly to repair.
