speed limit cut for japan engine
can,t aaa.. i dun know laa... that mean no rev cut for japanese engine? or still have rev cut. i confuse lor... 1 more question.... that mean if i cut speed limit that car can exceed 180kmh? teach me if i,m wrong..
where do i get a speed cut remover? cheap or not? i was driving my Proton 1.5 happily on Federal Hi-way til 150kmh then it wont go anywhere after that... so sad.... potong stim!!!
hmm ok my frenn..1 more question
i'm using mits 4G92 Dohc Non Mivec (Standard / No mod)...Try speed @ highway can reach 18x kmh n after that still can go but i'm scared to push more..
that my car doesn't have r speed cut!! or what wrong with my car..
any suggestion...telling the truth..
maybe ur speed cut is suppose to be higher than 180kmh or it doesn't have speed cut.....maybe just rev cut.....shouldn't be a problem with the engine.....
If you're driving a non-performance 1.6 and below more often than not you've reached your car's top speed instead of a speedcut. As stated by most folks here a TRUE speedcut (on older Japanese models) feels as if you lifted off the throttle at the set speed. Top speed on the other hand means you're flat out but the car won't go any further.
Pifectom, highest I've done in 4G92P auto is 175kmh so be happy with your results :)
i actually don't know about this engine...
i bought from chop shop n just install it..
my current engine what i know only got 2 spec
1. mirage 1991 grade R
2. mirage 1991 grade RS
which one i also don't know
http://specs.amayama.com/specs-mitsubishi-mirage-1991-october/18943 ..this for RS spec
http://specs.amayama.com/specs-mitsubishi-mirage-1991-october/18956 ..this for Grade R spec
my toyota camry can hit 190 km/h leh ....... if i rev more... can go up to 200km/h ... maybe .... coz my parents are on board... so i cant.... its 100% stock....... no speed limit cut etc......
juz went to the accessories shop.. he told me tat turbo timer also have this speed limit cut function.... true anot ?
i think speed cut only applies to jdm models only. if u got ur half cut from japan including the ecu, then most probably it will have speed cut (car will feel like off throttle at certain speed ussually 180).
other japanese cars in malaysia dont have speed cut. thats why our meter shows more than 180. unlike jdm cars. even jdm impreza have only 180km/h max.
if ur car is using jdm engine and can go more than lets say 180.. most probably is that ur speed sensor behind the speedo meter is not functioning. therefor not reporting the actual speed to the ecu.. which is good :)
if ur car cant go more than the speed it is already in, that means uv reached the top speed for ur car. not a speed cut. mod ur car la to be more speedier. :)
about the removal of speed sensor brings bad things to idling speed, i dont know. all i know is my proton satria runs all this while with a busted speed sensor.. and it runs fine.. i know this when installing rsm recently.. coz the speed is not showing(on the rsm). later change to new speed sensor (10-20ringgit) then everything is up on the rsm.
just my opinion..
