Speed-D's 9sec R32 GTR
  • Thread starter Thread starter Tom
  • Start date Start date
T
Tom
Guest
Sepang was shaken when this new kid on the block tore the strip during the
Sepang Drag Battle night. This new drag monster from Speed D is different
compared to previous entries from other garages. The R32 GT-R features some of
the most exotic and advanced parts and gadgets like the custom specified Quaife
6speed sequential transmission meeting with a 4 plate clutch from OS Giken. You
know it's a serious piece of drag machine...
Zerotohundred.com:
Can you tell us more about Speed D
Speed D:
It's divided in to two parts,​
  1. Speed D Motorsport has been established at Chiengkong Bangna 12km Bangkok
    Thailand for 3 yrs ago. We imported used and brand new parts, majority from
    Japan. The parts we supplied mainly concern on Wheels, Engine parts, Turbines,
    ECU, Electronic stuffs and also Special order parts.
  2. Speed D Pro-shop has just launch at Sunway, KL last month.
    We are focused on performance upgrade, engine
    management system tuning, engine conversion (transplant) and also maintenance
    job. Engine modification, is based on the engine standard spec from the
    manufactures, has done by, the head mechanic, who has been work in JUN AUTOMECHANIC (Thailand) for 10 years, has a lot of experience in modify various
    engine.
Zerotohundred.com:
why create the 9sec R32
Speed D:
The
Drag Project car is made to show our ability to produce the high horsepower
engine and also the very fast monster and to ensure that our standard is getting
closer to Japanese or US. Our goal is to achieve the 9-second quatermile time
and below
Zerotohundred.com:
What is the history of the car?
Speed D:
The car has been bought since yr 1993. Has been used as the streetcar, never
been in the
track.
Zerotohundred.com:
what is the future plans for the R32
Speed D:
1100 WHP with sequential or air shifted Gearbox and hydraulic torque
split controller
Zerotohundred.com:
Can you tell us more about it's
driver?
Speed D:
Mr. Dee, director and Tuner of SpeeD
D PROSHOP, who has got the master degree in Energy Technology. He has an
extensive competition driving background and provides us with great feed back to
set-up the car for whatever conditions
Zerotohundred.com:
Would you like to thank anyone?
Speed D:
We would like to thank EH Utara ,KSP , DMT,
SS racing
Zerotohundred.com:
Where is the GT-R going next?
Speed D
The car is
prepared to join the next Sepang Drag Battle in November
http://www.zerotohundred.com/features/speedd/Titanium%20Muffller_small.JPG
http://www.zerotohundred.com/features/speedd/trust%20twin%20intercooler3.jpg
http://www.zerotohundred.com/features/speedd/trust6speed.jpg
http://www.zerotohundred.com/features/speedd/tomeicrankcabstrut.JPG
Make:​
[TD]
Nissan​
[/TD]
[TR]
[TD]
Model:​
[/TD]
[TD]
R32 Skyline GT-R​
[/TD]
[/TR]
[TR]
[TD]
Engine:​
[/TD]
[TD]
Nissan
RB26DETT: 2.6 litre, Double overhead cam, Electronic fuel injection, Twin
Turbo​
[/TD]
[/TR]
[TR]
[TD]
Displacement:​
[/TD]
[TD]
Bored and
stroked to 2,700 c c​
[/TD]
[/TR]
[TR]
[TD]
Bore x Stroke:​
[/TD]
[TD]
87mm x 75.7mm​
[/TD]
[/TR]
[TR]
[TD]
Redline:​
[/TD]
[TD]
Exceeds 10,500
rpm​
[/TD]
[/TR]
[TR]
[TD]
Boost:​
[/TD]
[TD]
Exceeds 2.5
Kg/cm2​
[/TD]
[/TR]
[TR]
[TD]
Electronics:​
[/TD]
[TD]
HKS F Con V PRO
engine management system
HKS EDA/ETC Torque Spilt Controller​
[/TD]
[/TR]
[TR]
[TD]
Bottom:​
[/TD]
[TD]
Custom 87mm
forged pistons (x6)
Custom X-beam connecting rods (x6)
HKS full stoker counter balanced crankshaft
Custom 10 litre enlarged sump
Route 6 Crank Pulley
JUN high capacity oil pump
JUN oil sump baffle plates
ARP strengthened connecting rod bolts
TOMEI strengthened main crankshaft bolts
NISMO N1 upgraded water pump​
[/TD]
[/TR]
[TR]
[TD]
Top:​
[/TD]
[TD]
JUN 288/288
Lift 11.35 camshaft
Custom head channel modification and complete proprietary GT
cooling system upgrade
Custom porting and polishing of cylinder head and runners with
extensive flow bench profiling
HKS exhaust manifold gaskets (x2)
HKS metal head gasket 1.2 mm
JUN cam pulley (x2)
JUN brass valve guides (x24)
JUN camshaft bearing set
JUN GT surge tank (inlet plenum)
JUN intake gaskets (x3)
JUN oversized intake valves (x12)
Tomei strengthened head studs (x14)
UN tappet shims (x24)
JUN titanium valve retainers (x24)
Mines triple baffled cam cover plate assemblies (x2)
Nissan Infinity 90mm throttle body assembly​
[/TD]
[/TR]
[TR]
[TD]
Turbo:​
[/TD]
[TD]
APEXi IHI RX6
TCW77 turbo chargers (x2)
GREDDY DRAG Special intercooler (718mm wide × 277mm high × 156mm thick)
HKS Drag exhaust with Titanium Muffler
SARD Type J wastegate (x2)​
[/TD]
[/TR]
[TR]
[TD]
Fuel system:​
[/TD]
[TD]
SX Performance
1000HP fuel pumps (x2
100 braided fuel feed lines (x2)
80 braided fuel return line
Custom 1,450 c c injectors (x6)
RCI 30 litre fuel cell, with competition spec re-breather system
SX 6.0 bar high pressure fuel regulator​
[/TD]
[/TR]
[TR]
[TD]
Drive train:​
[/TD]
[TD]
OS Giken Quad
plates
ATS front 1.5 way carbon LSD
ATS rear 2.0 way high-lock rate Drag/SPL LSD
Custom solid engine mount system
HKS/Berc uprated drive shafts, front (x2) and rear (x2)
QUAIFE 6 speed drag gearbox with upgraded spline input shaft
JUN modified hi-torque transfer case system
Nismo N1 drive train mounts​
[/TD]
[/TR]
[TR]
[TD]
Aerodynamics:​
[/TD]
[TD]
NISMO aero
parts​
[/TD]
[/TR]
[TR]
[TD]
Suspension:​
[/TD]
[TD]
HKS Pro-drag
suspension strut system​
[/TD]
[/TR]
[TR]
[TD]
Brakes:​
[/TD]
[TD]
Endless rotors
(x4)
Endless C C M brake pads (x4)
Custom braided brake lines​
[/TD]
[/TR]
[TR]
[TD]
Interior:​
[/TD]
[TD]
Bride Zieg
Chrome-moly 6 point (competition certified) roll cage​
[/TD]
[/TR]
[TR]
[TD]
Garage:​
[/TD]
[TD]
Speed D​
[/TD]
[/TR]
wow, very great car and great interview!
all the best to Tony, Dee and Speed D boys.... and ZTH of cos, hopefully malaysia's drag standard will elevate to another level - the 9 sec level. :lol:
yeah me to mate
keep it
hope next
to be find cuore one :) :D :D :D :D
WUUUpeeessss wuuu pesssss wuuu singggg
whouh...9sec skyline...very fast dude!...so,when is the next sepang drag battle??..hope can see the car "flies"...hehehehe :P :D :lol:
najibkl, i believe for sure this gtr is the faster car - much much more faster i guess. from the records, the viswork gti's best time in sepang is 10.95 when he won the round 1 drag battle BUT fastest time was set by Garage R's evo - 10.34.
** fastest time for round 1 dragbattle (from the dragbattle official website)
1 - garage r evo - 10.34
2 - viswork gti - 10.92
3 - speed d r33 - 10/95
in the round 2 drag battle, the street set-up r32 (with only few hundred horses)from speed d that belongs to Dee's fren did a fastest time of 10.49. too bad didn't break the garage r's time but should be near enough or better if the car is stripped off its seat and with a set of semi-slicks....
now imagine this r32 with over 1000bhp, i think the 9 sec they claim should be within reach anytime.... personally, i think we should now compare this with our neighbouring countries' monsters - garage r evo, st power gtr, or maybe bangkok's monster evo or any other monster from borneo?? if they have la....
anyway, i think the drag event in the region has become more n more interesting... really forward to the next event...
