Speed Cut
speed cut?????????
cit the wayar petronas green!!not green!!if u wan more powerfull<take off the ori booost cut!!!only rm70 workmanship
ya lohh.... heheh... but tantat.. is it modify from ECU or u put one way valve... ??
if one way valve cannot lorr... dengerous maa... my engine koyak already becos of that lorr... huhuhu... now i'm using boost controler.. 1.0bar ok lorr...
bongweeyap said:
wondering how i m going to up boost my L2 to 1 bar in the cheapest way??
and of course must reliable lahhh????
any SIFU CAN HLEP????
frend... chipers way is using what we call tulang ikan.. like my.. im using gas controler.. buy from hardway shop... maximum boost only 1.0bar more than that your car will jecking.. huhuhu..
tantat, u had boosted ur car to 1 bar right???
then do u use any afc to control thge fueling?????
if just simply crank up the boost level is harmful to the engine lahhh.:)
i've been cutting the speed wire sensor on my jb-det engine ecu.. but the something happen which my check engine alert id turning on.. anyone l9 jbdet can share about speedcut 4 tiz engines?
