I reckon it would be a good idea to compile a spec sheet of subaru owners nationwide. This as well also helps with logistics when we plan doing some modification and etc.If you would like to add your list of mods kindly go ahead. A picture of the car,engine bay and dyno chart would be very nice as well.stock or strokers also welcome!
ENGINE
year/model:2002/s202
chassis code:GDB-B
Kerb weight :1330 kg
Fuel capacity:50 litres
engine code:EJ20
displacement cc:1994 cc
bore&stroke (mm):92.00 mm × 75.00 mm
piston/compression ratio:semi forged/8.00:1
connecting rods/crankshafts:stock
valve/spring/retainers:stock
cam:stock
cylinder head mods/gasket:stock/cometic head gasket
air intake:aps 65mm cai
fuel injection:stock pink
fuel delivery:walbro 255-lph in tank fuel pump
engine management:open souce (tune by papa snails)
turbocharger:stock vf34
blow off valve:greedy type S
exhaust system/downpipe/extrator:blitz nur spec R/3"local made/stock
intercooler:stock TMIC
cooling system:stock
peak hp:306.79 whp
peak tq:41.94
dyno type:dynojet
etc:
CHASSIS/DRIVELINE
spring (make@rate):titan 6kgf/mm front/4kgf/mm rear
shocks:titan high/low kit
addit'l suspension companents:all round superpro bush
transmission:stock
clutch/flywheel:stock
wheels/tires (make&size):stock
brakes (front&rear):stock
rotor (front&rear):tarox g88 front/stock rear
brake pad (front&rear):ferodo ds2500 front/endless sss rear
etc:brembo racing brake oil/sti branded hose
INTERIOR
seats:stock
gauges:sti genome boost gauge
ice:stock boxer sound system high end
etc:
EXTERIOR
bodykit:stock (no bodykit)
etc:
TRACKERS (personal best record)
SIC:N/A
PGC:N/A
etc:
ENGINE
chassis code:GDB-B
engine code:EJ20
cam:stock
peak hp:306.79 whp
peak tq:41.94
dyno type:dynojet
etc:
CHASSIS/DRIVELINE
transmission:stock
INTERIOR
seats:stock
etc:
EXTERIOR
etc:
SIC:N/A
PGC:N/A
etc:
