Spark Plug Keep On Blown..
impossible sparkplug can only last for a week ler...
check if u've got the correct plugs.... check ur ignition timing and so on.... ask ur mech tune it back for u lor....
not sure bout da ignition timing lar.. i dint kacau it bfore..
but a spark sound came out of engine..
+.. keep on jerkkin on low rev.. my car currently used is atoz..
Brader
Used the correct spec OEM NGK no BKR5ES-11 with resistor -tread 14mm with spark cap 11mm.
How about yr Plug cable connect correctly.....
thanks anyway guys.. actualy da problem is da stock high tension cable is crack.. can i find aftemarket performence engine parts for atoz or something to fit inside to add more power?? huhu..
