Here's the situation..
1.When air con on, free gear 0km/h, and engage first gear, slowly release clutch without pressing throttle pedal and the sound " tak tak tak tak" will appear. Have to rev til 2k and slowly release clutch only no sound. Sometimes happen even at 2nd or 3rd gear.
Without air con,there will be no sound at all.
2.Another thing is, sometimes on idle, my rpm can drop til 400 thus engine stalking while with air con. If that happen and I close the air con directly, the rpm wil return back to normal.
3.While driving, 2.5k rpm and next gear, sometime I can feel like my gearbox is falling down. Like the sound of "falling down" . Also happen only when air con is on.
Should be all caused by either the air con bearing or pulley or ???
Someone pls help identify this problem if u had similar problem before.
---------- Post added at 01:54 AM ---------- 6 hour anti-bump limit - Previous post was at 01:50 AM ----------
Oh no I posted in wrong section. Admin pls help me to moved to "car problem" section. Apologize for mistake as I used iPhone, and I though I clicked on the "car problem" section. Thanks alot
