SKUNK2 Lower Arm Replacement Bush
powerautohauz
((( God Level 30,000 RPM )))
SKUNK2 LOWER ARM REPLACEMENT BUSH
Skunk2's redesigned, low-deflection, polyurethane bushings are available separately and are compatible with all Skunk2 Rear Lower Control Arms and Rear Camber Kits.
Genuine Skunk2 polyurethane bushings act as bearings for quicker response and a more positive feel when compared to other manufacturers' bushings. Tearing and unseating problems normally associated with other fixed rubber bushings are eliminated by allowing the arm to rotate freely about the bushings. Fewer grooves within the inner diameter as well as special, radiused backsides help them last longer and avoid tearing and unseating. Thanks to the new design, bushing failures have been eliminated.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
