Silvertop 20V conrod problem
SE86
hello sifu out there..i need some help over here.. previously there was conrod sound from the engine and the engine was sent for rebuild changing conrod's..bearings and piston rings..
after 3 weeks of running some bashing to the engine..the conrod sound tends to come back again..is checked that the black oil level is at a high level..
wat can possible to cost this problem?its juz three weeks and the sound "tak tak tak" appear again..
tq for the help..
the engine is in stock condition..
is there enough oil pressure for the bearing????maybe u need to check the oil pump pressure also.... :adore: just my 000000000.1rupiah opinion...
ouh..actually the monitoring system have not been installed ...maybe should check..thanks pomen..
any other reasons??
