Shifting the O2 sensor?
SA6YEuro
Heres question i wanna ask 4 those who has done it? Issit possible to modify the location o2 sensor at the extractor of a OBD-O Ecu to the location of a OBD-1 Ecu?
OBD-O o2 sensor is located on the early part of the extractor itself rite? wherelse the OBD-1 is located at the lower part of the extractor where the 2-1 meet rite?
will the reading still b ok if its located there instead?
pls share if u hav done or know bout it..... thanx
hmm, i got some sort of related issue. I shift my o2 sensor from top part of extrator to the lower part of the piping, without changing ECU connection, when rev hard then engine check light will be on...until now i havent figure how to sort it out.
sounds like ur ecu is not readin properly or the wiring is messed up! after i consulted my mech n he says tt this might happen esp if the ecu is runnin on stock or a sensitive program......
honestly, i m oso not sure how mine will end up....... :confused_smile:
