Setting up for a 2zzge swap suggestions
GearSpeedKelvo
Here is the setup I'll be doing for the car but I need some suggestions on what kind of aftermarket parts I should use.
I wanted is just either U.S or Japan made aftermarket parts because they are more realiable.
2ZZGE engine JDM from a Celica SSII
K&N Air Filter
Headers - thinking MWR or suggest other brands and size?
Resonator - what brand do you suggest and size?
Pipings would be local but the bended parts will be for example 3.0 so that it will be 2.5 still.
2 Row Aluminum Radiator what brand do you suggest?
Samco Radiator hoses - I think this is the mostly use in the market.
Racing Clutch what brand and stage?
Flywheel what brand and stage?
Aftermarket ECU Apexi Power FC
Suspension
Tein Coilovers with adjustments inside the vehicle for soft or hard setting forgot what this is called.You can suggest what brand of coil over I can use either made in Japan or U.S?
front and rear aftermarket strut bars suggest what brand?
Other things needed to have it stiff or needed to be changed.
Tires/Wheels
16 inch SSR wheels bronze color original
Yokohama S drive for street
205/50 R16
Neova for races
Interior
Celica Gauge
Bride Racing seats (what kind do you suggest?)
Takata Seatbelt
These are made in italy but you can suggest other brands from Japan or U.S.
MOMO Race Steering wheel
MOMO racing pedals
MOMO Shiftknob
Brakes
4 lugs with Slotted brake discs front and rear (what brand do you suggest?)
tanabe brake pads or other brand you can suggest
Stereo
stock speakers
stock HU
Accessories
Carbon pins (any brand for this one)
Carbon fiber hood custom made
Voltex Wing
Bash plate for engine protection
JDM Carib front with foglights
All after market parts must be from Japan or U.S made only when you suggest.
The car will be daily driven but can still be use for circuit races.
The car is rarely being use anyway.
If there are no further problems on the engine I'll put turbo in it.
I'll be bringing all the parts and I'll just pay for the labor here.
You can add if there is something missing.
Thanks.
I wanted is just either U.S or Japan made aftermarket parts.
Suspension
Tein or BC Coilovers with adjustments inside the vehicle for soft or hard setting forgot what this is called.You can suggest what brand of coil over I can use?
BC coilovers are NOT from Japan or U.S. BC Stands for Bor Chuan, they are from Taiwan.
MOMO racing pedals
MOMO Shiftknob
MOMO is Italian, most parts made in Italy. Not U.S. or Japan.
Brakes
Didn't know Tanabe made brake pads.
Tanabe USA Inc.
All after market parts must be from Japan or U.S made only.
So yeah, you say want Japan or U.S. but you list Taiwan and Italian parts. This thread is meant to be a joke or what.
you're the 1 that wanna put 2zzge into AE111 right?
my suggestion is.. try all the things on ur list 1st.. then tell us the pros & cons of the item listed
Gudluck :burnout:
Shame to say.....but I don't even know that's their name because they keep appearing on aus mag btw thx mate HAHAHAHAHA
MWR does not produce headers for 2ZZ-GE, they are just a distributor for the PPE headers
Thanks for the kind correction. This is what I saw on the MWR.http://www.monkeywrenchracing.com/index.php?cPath=32_146
My mistake on the other aftermarket parts will change the list soon.
Any other suggestions besides on the steering wheel, pedals, and shift knob?
The tanabe brake pads we have it here in a shop and it cost around 4,500 pesos.Some use it besides the other brands. Going to change it as well if its not available in the market anymore.
This is not a joke I'm serious that's why I am asking.
Thanks.
