Sensors...
chinozie
Very Young Member... :D
guys...need help...
can we list out what are sensor do we have...
priority for 4AGE 20V (SVT/BT)
need help...
some of the list...is there any thing left out...???
Boost Sensors
Cold Start
Communications
Correction Factors
Crank Position
Diagnostics
Engine Temperature
Fuel System
High Altitude
Idle Up
Ignition System Control
Injection Duration
Injector Duty Cycle
Knock Sensor
Load Signals
Neutral Start
O2 sensor
Oil Pressure
RPM Signals
Starter Signal
Stop Lamp
Throttle Position
Vehicle Speed Sensor
Thank you in advance...
Update
Water Temperature
Air Temperature Sensor
Linear Throttle Position Sensor (is this the same with TPS)
Vacuum Sensor
any more aaaa ???
HELP please...
haha.. dunno correct or not....i think
shud hav 4 more sensors on the air cond system compressor
1) GAs pressure sensor
2) Compressor crank sensor
3) Compressor Oil sensor
4)Compressor Overheat sensor
tats air cond side tat i can helps...some model also got abs sensor as well..
thanks
eh i didn't even know that there were so many sensors..... o_O
I wonder if i'm missing any of those sensors....
thanx guys...
actually i'm searching for sensor that related to engine mostly...
to update my page :-D
