self poison
Greetings,
I'm new here and got one question.
I'm using a Perdana and recently just installed the Projector Headlamp, I know how to adjust the lighting Up and Down but how to adjust it Left and Right, because my left side lamp is projecting little bit to the left not center as compared to the right lamp
Feedback is appreciated.
Thanks.
i did retrofit on my headlight too using marimoto mini H1. Right side is parallel with ground. Left side slanting a bit towards the right. so left side cut-off line will be slightly higher. Maybe the lens were design like that because when i test it naked headlamp(without the cover) both parallel with ground.
Yes you can adjust up down and left right if you are using original one.
Stock v6 headlamp has vertical and horizontal adjustment screws, ori or aftermarket. But projector I don't know la.
HotRice, I wonder how is the project performance. Is it very good? I mean a lot brighter than stock?
way brighter and better man. Just make sure you buy a good projector avoid china g1 projector. Depending on how clear is your headlamp housing lens it could be on par with prius projector. Nice cutoff lamp etc.
My friend did also. Projector with HID fitment, much better then original. HID in projector also will not shine/glare onto oncoming cars as projector type is focused
I see, I know how to adjust it up/down but can't seem to find the thing to adjust it left/right.
The light seems brighter and it shoots quite far.
