SECTION Spec - RM/A8 suspension for S15
Orca7015
Japanese brand - SECTION also know as SILKROAD
Item is in working condition
Suspension come with adjustable pillow ball
Front Standard Rate/Free Length: 8K/H200
Rear Standard Rate/Free Length: 7K/H250
For further referrence, u may check out this website
http://babelfish.yahoo.com/translate_url?trurl=http%3A%2F%2Fwww.silkroad-jp.com%2Fsection%2Fa8.html&lp=ja_en&.intl=us&fr=yfp-t-701
* Executing nitriding in the piston rod, the cylinder and the outer tube. Coupled with the high pressure gas charging type mono tube shock absorber of the attenuation quality which stands up smoothly from low speed, actualizing the smooth operation where the friction is little. In addition, controlling the occurrence of aeration and cavitation even in extreme use.
* Total length pitch integral expression, it corresponds to wide setting with attenuation power 8 step adjustment.
* Strut type to make inverted system, rigidity and heat dissipation characteristic substantially rise.
* Damper, to spring and upper mount assembly conversion.
* Merit of nitriding
[Hardness = it has possessed the merit which] [abrasive resistant = superior] [corrosion-resistant = superior] [heat-resistant = superior] [deformation = small] is superior hard very much in comparison with heat treatment such as cementation or induction hardening.
interested, kindly PM or contact me at 0163900488
any chance u willing to swap?i using a set of tein super street and it was too soft for me
Bro, why selling la? This is one of the best coilovers for s15...using on mine also...Awesome...can whack potholes etc and wont break ur bones...Hopefully someone will buy...TEIN all is pure crap compared to this...free bump for you.
hi there..whats yer best price? kindly pm me pls, or text me at 0172000807 as i am not online all the time...tq
