SCR Titanium Head Stud
Syahz
Make for Performance and High Boost up to 5 bar.These stock for replacement stud are capable of achieving clamp loads loads of 230,000 – 260,000 psi. On top of the stud's added strength,we also increased the size of washer to increase the clamping surface area on the head.
Why Titanium
*much stronger than the competitions 8740
*Achieve higher clamp loads of 230,000-260,000 psi as opposed to the competitions 180,000-210,000 psi rating.
*Increased washer diameter to spread out clamping area.
*Hex broach on the top of the stud allows you to install the studs one by one while the head is on the car if needed
Specifications
11mm Diameter
Torque 95 ft/lbs
10 studs, nuts & custom washers
Assembly lube
Applications
1.Evo 1-9
2.7 Bolt 4G63
3.Fits all USDM, JDM and European Models
Price Starting From
For 4 Cylinder RM 7XX-RM 9XX
For 6 Cylinder RM 9XX-RM 1XXX
Pls Contact
Sport Compact Racing
