Satria Neo engine swap
gbis1985
Looking to swap standard 1.6 campro for somthing with a bit more grunt. see a few with EVO engines and the GSR turbo, but looking for somthing a bit different. been looking at buying an FTO for cheep and using the 2.0ltr v6 out of that....
first off i'm just wondering if it would fit?
what else would i have to strip out of the fto to make this work?
plus what custom parts would i have to look at getting made?
all help welcome.
live in UK so no probs with putting bigger engine in the neo. :driver:
y choose the FTO engine?..won't the front part of the car becomes imbalance due to the weight of engine(6 cylinders engine are suppose to be heavier, right?)...
Yeah ur right... just found out the someone put the v6 in to a GEN2 with i tight squeeze and its made the car really nose heavy.... think al scrap the idea.... if you've a better sugestion of engine to transfer please post....:hmmmm:
UK eh?
hmm... why dont u try the golf gti 1.8 engine?
if im not mistaken its a turbocharger ...
im not sure about the engine.. :|
:biggrin:hay being in the UK a can fit a 3.0 v8 if i wanted to... SEEN a 95 SAAB with a Koenigsegg engine in it....
just looking for the easy option... if i was to go for an evo engine i would like to have 4WD but how easy is this to do..... :driver:
can get a write off evo cheep and strip it.... any probles in doing this???
What i want my Neo to do is "smoke" anything Scotland has to offer... lol :smokin:
i was dreaming to own a neo with Evo 6 engine + 4WD inside. if 2WD, i think it will struggle for traction as neo is quite light for a such powerfull engine.
if stock evo6 engine+4wd with a set of good traction tires, i dun think it will be a prob, unless u r on FWD..
Satria Neo can fit most evo turbo engines. Get the 4G93t 1.8 . Good enough alr . If you still wanna stick to NA engine , and IF you have money . Get a VTEC b18c , Throw it inside your neo only, hahahaha ! RMB guys ,our neos cant out in 2.0cc , can put , just dont get block by JPJ . 'Play Safe' , stick to 1.8.
i've seen 4age 20v in neo engine bay..(onsale in mudah.my)
but to play safe better choice was 1.6mivec terbalik(cj chasis if i remember) and gsrT 1.8 terbalik (ck chasis)
As thread starter mentioned in his post, he is based in Scotland. Their road regulations are different with us, and it's possible for him to swap EVO engine in his Neo.
So, my bet would be go and swap an Evo 6 engine in your Neo. A lot of aftermarket performance parts as well for Evo 6 (just in case your still hunger for more power after the swapped).
