Satria-gti performance enhancement
KGhee
To fellow enthusiast out there, need some opinion on what is the most optimized engine performance i can get with a ~rm5k budget. My current ride is all stock, no mod done. As for the performance range, looking at increasing the low-mid rpm range. As of now, looking at either NA mod or supercharging (not sure if within budget though). Appreciate the feedback.
Guys, thanks for the suggestion. Couple of questions though:
Aaron: What do you mean by the MIVEC head? Just the cylinders head?
Boyzone: For low-boost BOT, does that mean the engine internals (heads, rods etc) need not be changed? And, how much would this mod improve the drive-ability in the low-mid rpm range?
Bear with me if some of the questions i have here is a little amateur-ish :P
5k for supercharging or turbocharging is barely enough... i would suggest NA mods...
- full tuned length exhaust mod
- drop-in k&n air filter
- lightened crankpulley
- safcII / emanage
- port n polish intake
Yup, no need to change.
low boost will not give u strong pulling, just a comfort like saloon car :biggrin:
change to mivec head...if you want to change head only oso can,but need to add Rspec to active mivec but the power is not as strong as if you change the whole things...better to get head,ecu,wiring,intake,throttle body,extractor and bla bla bla or all above your block change to mivec parts...
within 5k budget,i think you need to sell back your 93 head and all above your block,then it will be enough coz to get mivec head and bla bla bla is so expensive now...:biggrin:
long live to MIVEC~!!!:driver:
just curious..if 4g93 change to mivec head..do JPJ 'kacau' if they conduct 'operasi'..is it illegal or legal?
Bump: just curious..if 4g93 change to mivec head..do JPJ 'kacau' if they conduct 'operasi'..is it illegal or legal?
it is legal bro,they only check on your block whether you punch number on it or it is original...they also check on your exhaust system sumtimes...dont go straight below your fuel tank...but mine also straight below tank...:biggrin:
just slow down your car if u facing the jpj road block,dont use very noisy muffler...
TIPS: jpj loves to stop your car if you hood is in black colour and white body...thats what i heard from jpj itself...:biggrin:
you have to ask yourself. TURBO or NA. then we will do the recommendation. TURBO no end. NA got limitation but i would say enough for street and even occasional track.
Hmmm, after some thinking thru...i would prefer to stick with a NA setup. Main reason is i'm more interested in improving the drivability of the car in the low-mid range.
KGhee,
Just follow bro skywalker recommendation if you want low mid range for NA way ... It would be better if you can add in a street cam... like 268... Else you can go for turbo kit... no need to high boost... confirm increase low mid range... some one selling at the market place... installation plus tuning only less then 5k.... check it out...
BOT might casue u more...in case if u need to up boost, u have to mod oil pump, low compression piston, intrercooler
My 1.8 MIVEC:love: is not that power...maybe i don't put enogh $$ into it...!!!
But can play with BMW brand new 5 series geh...:burnout:!!!
But don't compare with GSR lah...:banghead:
anyone modify simems based 4g93p ??mind share most of the ppl recommended convert to mmc based, my pocket not deep enough to convert mmc. any recommendation beside change to mmc??
change to mivec head,also the wiring and ecu..then install RSM..n the power always come..
if u use the same block ur engine number is the same..jpj akan cek no enjin.only change the mivec head..
totally agrred. siemen based gti is like a curse. cannot do any tuning.i change to gsr ecu altogether..
