SARD Fuel Regulator ORIGINAL
powerautohauz
((( God Level 30,000 RPM )))
SARD FUEL REGULATOR
**100% ORIGINAL WITH SECURITY SEAL**
SARD fuel regulator offers appropriate fuel pressure for high-performance application. SARD fuel pressure regulator also allows an increase of factory injector discharge rate by configuring fuel pressure.
- Each SARD fuel pressure regulator is equipped with exclusive design parts to stabilize its already excellent fuel pressure and to enable detailed adjustment.
- Service hole (1/8PT) is attached to the regulator for installation of fuel pressure sensor and fuel line for additional injectors.
- Vacuum nipple turns 360 degrees to simplify piping.
- For the fuel line fittings, you can choose either 8mm hose nipple or AN#6 adaptor bolt, both blue alumite coated. (For Type-RJ, AN#8 fitting is also available)
- The body will appeal its good fell of chipped-off aluminum in your engine compartment.
- Each regulator comes with a holder to make your installation easier.
Color Available: Red, Blue, Gold & Silver.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
