rpm prob..help me
apisanif
guys..y my rpm wont stable?? after had a ride,when i stop at traffic lite or entering a junction suddenly my engine stop after i change to low gear..rpm drop too low and not stable..it b'come worse when i switch on air con..
im using vr4 engine..
pls help me..:retarded:
checking ur timing. Get a reliable mechanic to get it tuned.
If the problem still not solved... start to look into possibility for a faulty stepper motor.
Or a faulty TPS sensor. Trottle position sensor
Mitsubishi motor TPS tend be become faulty easily. You can saty it's faulty especially when idiling, u hit rpm till 3k release it and the engine goes dead or almost dead. That u can conclude that it's faulty TPS sensor.
owh..i thought im the only one got this prob..lol
erm..which one is the best replacement for current throttle body??
mivec,evo or vr4???
mivec,evo or vr4???
it's normal bro, i've also had this problem, drving a ford b8, same old s**t. problem easily solved by changing the sensor
