RPM drops when take sharp corner
ae101svt
Sifus...
I post this question for a fren of mine. He just finished doing a transplant wif 101SVT into his AE92... but when he take a sharp corner...the RPM will drop and sometimes the engine stall.. he go back to the workshop and the boss said is bcos of the fuel pump problem then they changed it. but the problem still persists... need help pls....TQ
p/s: he's using ae92 original fuel tank with very noisy external fuel pump.
external?? iam having similar problem while taking hard corners, fuel level goes to one side when cornering thus insuffiecient fuel goes to the fuel rail. ask him if dis also happens when the tank is full, if it doesnt, den a fuel surge tank is supposed to be in his next mod. or, just remember to fuel up, and consider 1/4 tank is empty. easy..
hi sifu,
i am also facing the same annoying problem when taking corner at low fuel level.
how much normally the fuel injection fuel tank for toyota seg?
or should just use fuel surge instead?
thanks sifu...
i'm olso facing the same problem lastime. when taking sharp corner & break
when asking the formen, he said wether it from fuel pump or fuel filter. dunno la havn't change yet.
the problem isnt both of dat, there r many ways to curb dis. surge tank is one of them, or u can just mod to fit in another fuel pump, to the other side of the tank. dis is good for future upgrade, but beware of the max fuel flow rate the fuel regulator can witstand. too high a pressure may fark it up
john...for seg u have to get a 1.6 4afe seg tank or FXgt fuel tank.....both will fit seg.
for LE,no choice you have to getthe rarset part for LE.i got mine last time after looking for 3years!!! a ae82GT fuel injection tank........................
to mod another fuel pum is also no use......the most important in fuel tank is the buffer itself......either you make it on the ori tank itself or use a surge tank...........surge is better in every way except the complication of installing,make it and sorting out the hoses and such.
good luck!
For my EE90 chassis, I've installed with AE101 EFI fuel tank. with this, I do not face the jerking problem, and easier to do my exhaust piping too.
hmmm
last time also i experienced same also (with original tank(no mangkuk dlm wan)..but after changing to fuel injection tank noooo problems at all except for my fuel gauge ,,needle not accurate .up and down while cornering...apart from that its ok
ive been planning to mod the mangkuk inside there, but whattheheck. a fuel surge sounds more dramatic, twin fuel pump is one of the solution bro, but u have to place the line inside the tank to specific places. its according to ur tank shape
I'm driving Corolla SE with 20V engine as well. Although I'm using EFI fuel tank but still facing fuel surge in Sepang track at those tight corner when the fuel level left 1/4. The only solution is Fuel Surge tank.
Please refer to below pic for the surge tank installation diagram.
http://toyotaperformance.com/images/fuelsys.gif
Pic taken from below URL: Please refer to below page for more detail on how to build own surge tank.
http://toyotaperformance.com/surge_tank.htm
hello bros, interesting topic, i'm driving 1987 L.E 4agze engine, i had problem to find L.E GT feul tank when i conv my car few years back, so i use an external fuel pump instead, very bising one. had same problem, rpm dropped when taking sharp corners and driving uphill, but only when my fuel level is below 1/4. but the problem never occurs when fuel is above 1/2. had the same advice from various garages n mechanics. a surge tank sounds the best solution. anybody knows how much does it cost? tq :wink:
u can custom a set urself, plus a 2nd fuel pump. just rewire this 2nd unit to the existing wiring of the 1st unit. or u can just follow the instruction above
