Ron95 comparison between different Gas station
What is the negative feedback you get from using RON95.
  • Drop in engine power
    Votes: 0 0.0%
  • Lower mileage
    Votes: 0 0.0%
  • FC increases
    Votes: 0 0.0%
  • Engine knock
    Votes: 0 0.0%
  • Starting difficulties
    Votes: 0 0.0%
  • Rough Idling & noisy engine
    Votes: 0 0.0%
  • Engine not responsive
    Votes: 0 0.0%
  • More frequent downshift
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
all ron95 are the same - less engine response, noisier engine, and paying the same price....not saving anything in fact...luckily my area there still can pump ron97 but expensive...rm2.05 per litre...some place i went, 100% ron95, especially petronas..
ha...lucky i still feed my gaban with ron97...although its expensive :banghead: but too bad im a person who taken my car well and always try to give it the best to it...:rolleyes:
*State here the brand you use: Petronas Primax 95
1. Mileage: Bad
2. Power: Worst
3. Engine knock: Slightly
4. Engine's idle and sound: Rough
5. Starting: Easier
6. Damage or symptom that occurred or happen after you tried Ron95.. If i drive in jammed stuation, heating, no power and my auto gearbox changing not smooth.
7. Engine Type: Honda Vtec F20B DOHC
aiyoh in place..mostly shell station with ron 97 always run out..have to travel around for finding..sometimes have to pump ron 95..what to do..
compared petronas, shell and esso/mobil.........petronas the worst !!!
killing my engine soon......swap back to ron 97 fr mobil
Petronas & SHeLL RON95
1. Mileage:OK
2. Power: Bit worst
3. Engine knock: Nope
4. Engine's idle and sound:Hmm... Ok
5. Starting:Normal
6. Damage or symptom that occurred or happen after you tried Ron95:Dunno..Wailt till 4 or 5 month when becoming KONG!!
7. Engine Type:DOHC (MYVi)
*State here the brand I'm using: RON 97 & V-Power
1. Mileage: GOOD
2. Power: MANTAIN
3. Engine knock: PROVEN WITH FINE TUNING
4. Engine's idle and sound: CRAZY!!
5. Starting: Easier
6. Damage or symptom that occurred or happen after you tried: DUN TRY OVERREV.. THEN KABOOM
7. Engine Type: B20B HC
after using caltex 95 from shell,can c sum improvement on the milleage,usually my myvi 1 bar will last btw 60km to 80km using shell,then tis time caltex can last till 99km ngam ngam 1 bar..1st time can last so long ....Tat day tried petronas 95,put pump rm 20 onli la,the nxt day 3 bars gone d wif 80km on trip meter(normal driving) If talk bout performance,i guess all bout the same..wif ron 95
Hehe... as for conclusion... pls la dun pour ur car with unhealthy ron 95... huhu....
summore, let us continue using ron 97 and above.. i'm saying this because whenever the price is increase to rm2.70 for RON97... why can we still afford for it (RON97) although very2 full of cursing our G'.
Now the price about rm2.05 only... haiyah just balun lah .......... can save ur engine oso... Otherwise use the RON95 but MUST re-tune ur car....
Thanx you fren...........:wavey:
