Replace Gear Oil
Nope, its a seperate item.
For a full service you need
1) Toyota ATF WS Fluid x 2 Tins ( 4 Litre Each , 1 for Flushing ; 1 for Fill Up)
2) ATF Oil Filter ( As above )
3) ATF Oil Pan Gasket
ok great thanks alot for the info... is taking off the oil pan to change the filter like some kinda of major op? should be an hours work right?:idea:
It take about 2 hours..... need to idle the car for 30 mins in order to flush all the old fluid at every gear.
---------- Post added at 10:31 PM ---------- 6 hour anti-bump limit - Previous post was at 10:25 PM ----------
In china is250 is no need to change ATF oil for normal drive.Only need to change Diff oil for rear gear box.
Yea, even in US it was not part of the maintenance schedule (Claimed Maintenance Free ) . But i take it as a preventive maintenance service. I dont believe fluids are maintenance free, the viscosity will wear down eventually. Wont take any chances on this. Just my 2 cents.
Note : BMW E90 & E60 initially claim their GB fluid are maintenance free , but after after several reports of GB failure ( due to our extreme weather ). There now are required to be replaced after a certain mileage under the BRSI schedule or warranty period.
Hi Guys,
Did the reaplcement of ATF filter as well. The gear shifting is actually very much smoother than before. Glad I did it, and my ATF oil was kopi-o kau! :D So decided to flush it too. And it wasn't that long. I reckon if just the ATF oil change with the filter as well, it was like an hour.
IS 250
Hi Steve,
I went to Vision Auto (Sunway). As fr the pric, I need to take a look at the receipt again, cant remember :D
is 250
