Rempojo coating
Rempojo coating
A very good workmanship. Very friendly guy to. Will recommend more friends to u. Just got my 4G63 rocker cover sprayed it blue sand type( not powder coating type)
thanks man :burnout:
CANDY PURPLE
Finishing: Candy/Glossy
Sure TOUGH, DURABLE, LASTING AND HARD TO PEEL OFF THAN 2K PAINT because its 2 Layer Powder coat.
Hi Temp over 200 degree Celsius Oven bake Electrostatic COATING Material.
RM190.
0123559818 JOE
BANDAR TEKNOLOGI KAJANG
WORLDWIDE COURIER ACCEPTED =p
Monday - Friday: Send your item today and receive it the following evening
Saturday & Sunday: Send your item early in the morning and you will receive it in the evening the very same day. The whole process usually takes around 4-5 hours to be completed.
I'll do my very best to ensure all items sent to me to be completed in an estimated time given.
This is a part-time job, you are advised to call beforehand so I can estimate the completion period.
ON GOING Project:
Custom vein satin yellow powder coating (wah seng setapak style in powder coat not TAR...)
Combination two tone Wrinkle black and wrinkle ermm... dunno yet​
I would like to Powder Coat my rims.
Thinking to change it to Candy Black or GREY (dark color).
Grey colour now..
Could you advice the pro and con about it.
Such as the reliability of the coating.
Easy clean the brake dust? Or sticky type paint? Prefer it to easily clean.
How long the approximate life time of the paint? Easily crack or such?
Paint correction can be done if “calar” or else…?
Or need to repaint all over again?
thks
Grey colour now..
thks
Powder coating is a process that uses static electricty to cause powder pigments to adhere to the part. It is then baked in an oven at 300 to 400F degrees. The heat causes the powder to "melt" into smooth coating that is very scratch resistant. Cured properly it won't chip, peel, or come unglued. Time and temp are different for different powders and substrates. The powder is usually an epoxy that is much harder span more longer and hard to scratch than liquid base paint.
its easy to clean if you choose gloss or semi gloss finish.
since the powder coating is base from powder, i dont think it can b touch up like liquid base paint otherwise you need to restrip n recoating again. :)
TEXTURE YELLOW
RM150
TEXTURE YELLOW CAMPRO VC
WRINKLE RED AND BLACK CAMPRO R3 PLUG COVER
SILVER VEIN
RM160
SILVER WITH CRYSTAL CLEAR
RM180 Double Layer Powder coating
BLACKENRED WRINKLE
RM170 Two tones
0123559818
fb: rempojo coating
CANDY BLUE
DOUBLE LAYER POWDER COATING
RM190.
To see more photo and updates feel free to visit or add REMPOJO COATING facebook
CALIPERS
WRINKLE RED (single layer powder coating)
WRINKLE BLUE (single layer powder coating)
SUN GOLD (single layer powder coating)
CANDY BLUE over silver (double layer powder coating)
Picture credit to TCC coating
GTO 6 SPEED CALIPER BRAKE N ROTOR
CANDY TEAL over silver (double layer powder coating)
seems like project MU rite??
http://image.hondatuningmagazine.com/f/8977279/htup_071227_z+2002_honda_s2000+advan_rg_2_wheels_project_mu_brakes_calipers.jpg​
POWDER COATING 4 POT CALIPER PRICING
Double layer Powder Coating 2 times oven baking
(Candy blue, Red, Teal, Yellow)
Front Caliper rm90 x 2 = 180 (valve cover double layer powder coating rm190)
Rear Caliper rm80 x 2 = 160
Rotor Disk rm50 x 4 = 200
Total rm540
4 (Four) caliper W/O rotor disk only rm340
Single layer powder coating
(Wrinkle Red and Blue, Gold, Silver, Mirror Red, Blue, Yellow)
Front Caliper rm70 x 2 = 140
Rear Caliper rm60 x 2 = 120
Rotor Disk rm30 x 4 = 120
Total rm380
4 (four) caliper W/O rotor disk only rm260
facebook: rempojo coating
TEXTURE BLUE SUBARU INTAKE
(not powder coat)
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs1371.snc4/164343_145851352138732_100001416047275_261473_8184650_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs073.snc6/168320_145851398805394_100001416047275_261475_4194039_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs060.snc6/169073_145854708805063_100001416047275_261500_3668257_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs884.ash1/179196_145854745471726_100001416047275_261501_4256530_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc6/hs080.snc6/169016_145854778805056_100001416047275_261502_2470178_n.jpg​
M70 V12
All parts are sandblasted & ready to coating job
Intake manifolds - Wrinkle Red (PC)
Valve Cover - Silver (PC)
Fuel Rail Cover- Texture Red (Not powder coat since its made from plastic)
Done
WRINKLE RED
TEXTURE RED
SILVER
Big thanks to Tom Goh@ZTH Land Lord by sending part to coating with me.
WRINKLE BLACK EDELBROCK
B18 PERFORMANCE INTAKE MANIFOLD
powder coated wrinkle black
keep this thread clean. pls PM CALL or SMS for any inquiries.. tenkiu:biggrin::biggrin:
