Remove speed limiter
thezed
Hi there,
What is the best methods to remove the cut off? The "Z" moved up to 180kmh in a split second... I reckon that theres ECU remapping at N1 racing which removes the cut off and improve throttle response. Anyone has done this? any impact to the fuel economy? or reliabiliy?
you can done by adding those device such as SLD and others. they are juz plug and play to Z.
Remapping ECU is not only has the function to remove speedcut but u can actually tune up your car as well. But the price isnt cheap though.
Or putting any aftermarket standalone ECU like haltech platinum will remove the speedcut away as well. But make sure u have a good tuner to tune for you.
